Tilbage til HIFI4ALL.DK 26. juli 2026 | 21:07
Emne Emne: Rothwell - In-line - formeget gain! (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
vnv nation
Sendt: 11 Maj 2006 kl. 23:12 | IP-adresse registreret
Jeg har præcis nedenstående problem.
Er der nogen der har prøvet Rothwell´s produkt og kan anbefale eller fraråde det.
http://www.rothwellaudioproducts.co.uk/
Here's the solution to a problem from which far too many audiophiles suffer - too much gain in the system. The symptoms are easy enough to spot - the volume is plenty loud enough with the volume control set to the 9 o'clock position, too loud with the volume control at 10 o'clock, and fine control at low levels is impossible. This may seem like nothing more than a minor irritation, but in truth the performance of the system is being compromised. Although potentiometers work reasonably well over most of their operating range, they are notoriously problematic at extreme settings. The most obvious problem is channel imbalance - one channel will fade out (or fade in) quicker than the other, causing the stereo image to shift to one side - but on a more subtle level, the music may sound veiled and indistinct with the volume control turned down to the point where it is nearly off. Some people have tried to cure the problem by fitting a more expensive volume control only to find that it doesn't do much good. That's because the volume control isn't really the problem.
Inline attenuator
Its the excess gain in the system which is the real problem. That in turn forces you always to use the volume control over a very limited portion of its travel. What's needed is a way to reduce overall system gain without compromising sound quality and without major modifications to the equipment itself.
The Rothwell In-Line Attenuators are the answer. These audiophile devices simply plug into any input sockets and reduce signal levels by 10dB. They can be used with integrated amps or pre/power amps, and are compatible with equipment over the entire price spectrum, from budget to extreme high end.
When used with integrated amps (simply plug them into any input sockets, then plug the source component into the atenuators) the volume control will be two or three "hours" further round its range than it was before, giving better conrol at low levels and operating well away from the end stops. When used with pre/power amps, there is an added benefit.
RCA Inline attenuator. Priced at £39 per pair including VAT
Although the attenuators can be used on the inputs of the pre-amp in exactly the same way as they would be used on an integrated amp (with the same benefits), alternatively they can be used between the pre-amp and the power amp to even greater effect. When used this way, not only is system gain reduced by 10dB, but the signal to noise ratio is improved by 10dB. This pushes the noise floor down enough to create an inky black silent background from which the music can emerge with better resolved fine detail and transparency. This applies to even very high-end and very expensive pre/power amps.
So, if you recognise the symptoms of excess gain in your system, the Rothwell attenuators are the answer. Don't be put off by the fact that you could pay much more money for an audiophile tweak such as a set of spikes. These attenuators give real, measurable as well as audible improvements and are perfectly at home between pre and power amps costing as much as a family saloon, and for users of balanced equipment we now have a balanced version available.
mvh Thomas
http://www.hifi4all.dk/forum/forum_posts.asp?TID=38934
Til top Vis vnv nation's Profil Søg efter andre indlæg skrevet af vnv nation Besøg vnv nation's Websted
vnv nation
Sendt: 12 Maj 2006 kl. 22:36 | IP-adresse registreret
Slet ikke nogen der har et bud?
mvh Thomas
vnv nation
Sendt: 14 Maj 2006 kl. 11:15 | IP-adresse registreret
Kom nu, der må være nogen derude der har erfaringer med dette!
mvh Thomas
Bryde
Bruger siden: 06 April 2003
Sendt: 14 Maj 2006 kl. 11:31 | IP-adresse registreret
Jeg har sådant et par dimser ( balanceret version ) .
De fungerer fremragende og er meget flot bygget med fine
komponenter . Anbefales 100% .
Mvh Peter
Til top Vis Bryde's Profil Søg efter andre indlæg skrevet af Bryde
vnv nation
Sendt: 14 Maj 2006 kl. 13:18 | IP-adresse registreret
Hej Bryde
Dejligt at høre fra nogen med viden på dette område.
Kører du med forforstærker og effektfor. eller intgr. forstærker?
Hvis du kører med forforstærker og effekt. hvor har du placeret dine dimser?
mvh Thomas
willold
Bruger siden: 12 April 2003
Sendt: 14 Maj 2006 kl. 13:45 | IP-adresse registreret
har også et sæt RCA - placerer dem så langt henne i kæden som muligt; altså tættest på effektblokken..
mvh,
mikkel, KBH
Til top Vis willold's Profil Søg efter andre indlæg skrevet af willold
willold
Sendt: 14 Maj 2006 kl. 13:46 | IP-adresse registreret
vnv nation er i øvrigt et fremragende band ;-)
vnv nation
Sendt: 14 Maj 2006 kl. 13:49 | IP-adresse registreret
Tak, mikkel..
Jeg glæder mig til de kommer (rothwell´s plugs).
Jep, var du også til koncert for nogle uger siden?
Thomas
mvh Thomas
willold
Sendt: 14 Maj 2006 kl. 14:15 | IP-adresse registreret
nope, går ikke så meget til koncert for tiden(5mnd gammel søn..)
er også mest glad for Empires/burning Empires. EBM er egentlig ikke rigtig min genre, men vnv og covenant rammer rigtigt i ny og næ ;-)
Bryde
Sendt: 14 Maj 2006 kl. 18:54 | IP-adresse registreret
Hej igen
Mine dimser sidder i indgangen på effektforst.
Det fungerer fint , da man let får alt for meget gain ved balanceret drift .
Mvh Peter .
vnv nation
Sendt: 15 Maj 2006 kl. 17:34 | IP-adresse registreret
Nu kører jeg ikke balanceret, men der er formeget gain alligevel.
Superservice bestilte i torsdags fra England, lå der da kom hjem, nu skal der testes.
mvh Thomas
Simon R
Bruger siden: 14 Maj 2005
Sendt: 29 Marts 2007 kl. 17:19 | IP-adresse registreret
Bringer lige denne tråd op igen selvom den har ligget død et stykke tid...
Hvordan har problemet med for meget gain vist sig? Har det været - som beskrevet hos Rothwell - at lydniveauet er for højt?
Eller har der været for meget sus?
Eller har der været brum?
Til top Vis Simon R's Profil Søg efter andre indlæg skrevet af Simon R
vnv nation
Sendt: 29 Marts 2007 kl. 17:53 | IP-adresse registreret
Lydniveauet var for højt...
Kan stadig kun anbefale, hans lille lette løsning.
mvh Thomas
Simon R
Sendt: 29 Marts 2007 kl. 18:36 | IP-adresse registreret
Ok - tak for svaret.
Har selv lidt problemer med brum, der _måske_ er relateret til gain. Måske jeg skulle prøve sådan et par fætre.
