Tilbage til HIFI4ALL.DK 19. april 2024 | 06:48
Emne Emne: Dali 18 II midrange replacements? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Tomas Osterman
Bruger siden: 28 December 2021
Lokalitet: Sverige
Sendt: 10 Januar 2022 kl. 17:24 | IP-adresse registreret
Hi,
I have a pair of Dali 18 MK2 where I need replace both tweeters and midrange speakers.
The problem is the midrange speakers. The original midrange speakers ( I have 1) are Audax Tx11x25 JSN.
This particular speaker seems very rare and difficult to find. Audax does not produce these anymore.
Does anybody know of a good replacement for this one ?
( Reading this excellent forum tells me that:
1, the Dali 18 MKII are very nice speakers with lots of power if one feed them by a powerful amplifier.
2, the tweeter and the midrange speaker elements does sometime break. Unclear why so far. )
Tweeters can be replaced by the Audax TW025A0
which are available from https://www.cadaudio.dk/
( I have spoken to Karsten.)
Thanks in advance,
Tomas
Til top Vis Tomas Osterman's Profil Søg efter andre indlæg skrevet af Tomas Osterman
Sendt: 10 Januar 2022 kl. 18:35 | IP-adresse registreret
If I were you, I would try to find some other used DAli 18 mk2 instead....it's much easier, than find some mid and tweeters.
Digital_Thor
Bruger siden: 06 Maj 2010
Sendt: 11 Januar 2022 kl. 19:32 | IP-adresse registreret
You have tons of options.... simply a matter of your skills and the amount of time and money you want to put into the project
But no worries... help is just around the corner.... the midrange is easily found by the guy who unpacked the first set of Dali 18 that came to Hifiklubben:
It is apparently this one:
AUDAX HM100Z0 100mm - HDA cone - 93 dB - 110 x 110mm - midrange - 1,0 kgs
It's 88 Euro around 660 danish kr..... so not super cheap... and you can get a set of Dali 18 mkII used for 1200 kr.
But then you need to pick them up... and transport of two small midranges might be cheaper.... and I think the HM100Z0 is of better quality than the original one you have
kevin123
Medarb. - Computersalg.dk
Bruger siden: 09 April 2016
Sendt: 12 Januar 2022 kl. 09:50 | IP-adresse registreret
Hvis du søger på Dali 18 mk II på nettet , kan du købe 2 stk for 800 kr , så har du også 4 basser i reserve .
kevin123
Sendt: 12 Januar 2022 kl. 11:01 | IP-adresse registreret
Söker du efter Dali 18 mk II på nätet kan du köpa 2 stycken för 800 DKK, så du har även 4 basar i reser
