Sendt: 01 August 2022 kl. 19:43 | IP-adresse registreret
"Improvements in this unit over the standard Croft RIAA phono stage is the two mains power supplies and tube voltage regulation. As incredible as the standard RIAA is, yes you can hear the difference in this RIAA R and, yes, it is worth the extra money if you can fit it in your budget". --Gene
The Croft Acoustics RIAA R Phono Stage takes its design from the Micro 25 R Pre Amplifier, featuring an all valve signal path with heavily regulated power supplies and two toroidial mains transformers. The RIAA R is ideal for all Moving Magnet cartridges and can also be used for high output MC cartridges, and offers impressive depth, detail and scale that only a valve design and a Croft product can.
The RIAA R offers improvements over the phono stage included in the Micro 25 R, characterized by impressive detail and scale, with lifelike precision and an authorative valve soundstage.
