Tilbage til HIFI4ALL.DK 16. april 2024 | 17:00
Emne Emne: Zanion’s Hjemmebio (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
ZanioN
Bruger siden: 20 Februar 2005
Sendt: 29 November 2009 kl. 22:35 | IP-adresse registreret
Så er der kommet så meget udskiftning og nye lokaler så der måtte en update til
Set up:
Reciever
Harman/kardon dpr-2005
Specs
Audio
Stereo Mode
Continuous Average Power (FTC) per Channel : 120 Watts per channel, 20Hz – 20kHz, @ <0.15% THD, both channels driven into 8 ohms
Seven-Channel Surround Modes, Power per Individual Channel,
All Channels Operating at Full Power :
Front L & R Channels : 120 Watts per channel @ <0.15% THD, 20Hz – 20kHz into 8 ohms
Center Channel : 120 Watts @ <0.15% THD, 20Hz – 20kHz into 8 ohms
Surround Channels (L & R Side, L & R Back) : 120 Watts per channel @ <0.15% THD, 20Hz – 20kHz into 8 ohms
Input Sensitivity/Impedance, Linear (High-Level) : 200mV/47k ohms
Signal-to-Noise Ratio (IHF-A) : 97dB
Surround System Adjacent Channel Separation :
Dolby® Pro Logic® I/II/IIx : 40dB
Dolby® Digital : 55dB
DTS® : 55dB
Transient Intermodulation Distortion (TIM) : Unmeasurable
FM Tuner
Frequency Range : 87.5 – 108.0MHz
Usable Sensitivity : IHF 1.3µV/13.2dBf
Signal-to-Noise Ratio (Mono/Stereo) : 70/68dB
Distortion (Mono/Stereo) : 0.2/0.3%
Stereo Separation : 40dB @ 1kHz
Selectivity : ±400kHz, 70dB
Image Rejection : 80dB
IF Rejection : 90dB
AM Tuner
Frequency Range : 520 – 1720kHz
Signal-to-Noise Ratio : 45dB
Usable Sensitivity : Loop 500µV
Distortion : 1kHz, 50% Mod 0.8%
Selectivity : ±10kHz, 30dB
Video
Television Format : NTSC
Input Level/Impedance : 1Vp-p/75 ohms
Output Level/Impedance : 1Vp-p/75 ohms
Video Frequency Response :
Composite and S-Video : 10Hz – 8MHz (–3dB)
Component Video : 10Hz – 50MHz (–3dB)
General
Power Requirement : AC 220-240V / 50Hz
Power Consumption :
Standby: 8.9W
Idle: 58W
Max (7 channels driven): 1073W
Unit Dimensions :
Width : 440mm (17.3 inches)
Height : 114mm (4.5 inches)
Depth : 476mm (18.8 inches)
Unit Weight : 10.5kg (23.1 lb)
Front ht:
B&W dm604s3
specs:
  • 1" diskant, 7" mellomtone, 2x7" bass
  • Frekvensgang: 39 - 20.000Hz (+/-3dB)
  • 30 - 30.000Hz (+/-6dB)
  • Følsomhed: 90 dB
  • Impedans: 8 ohm (minimum 3)
  • Delefrekvenser: 450Hz, 4 kHz
  • Størrelse: 99,4/23,6/39,8 cm (H/B/D)
  • Vægt: 29,2 kg pr. stk
  • Center ht
    B&W htm61
    Specs:
    • Kategori: : Centerhøjtaler
    • Diskant: : 1” aluminium-diskantdome med Nautilus-rør
    • Mellemtone: : 6” FST-mellemtone med vævet Kevlar-membran
    • Bas: : 6,5” bas/mellemtone med vævet Kevlar-membran
    • Frekvensgang (-3dB): : 49-22.000 Hz
    • Frekvensgang (-6dB): : 42-50.000 Hz
    • Impedans: : 8 ohm
    • Følsomhed: : 90 dB
    • Bi-wire: : Ja
    • Magnetisk afskærmning: : Ja
    • Størrelse: : 19,8 x 54,4 x 33,9 cm (HxBxD)
    • Vægt: : 15,4 kg
    • Farve: : lys eg
    • 3-vejs basreflekskonstruktion
    • Flowport-refleksrør
    • Impedans: (minimum 3 ohm)
    • Delefrekvenser: 350 Hz / 4 kHz
    Bag ht:
    B&W DM685
    Specs:
    • Kategori: : Kompakt
    • Bas/mellemtone: : 6,5” bas/mellemtone med vævet Kevlar-membran
    • Impedans: : 8 ohm
    • Følsomhed: : 88 db
    • Bi-wire: : Ja
    • Vægbeslag inkluderet: : Ja
    • Størrelse: : 34,0 x 19,8 x 33,1 cm (HxBxD)
    • Vægt: : 7,0 kg
    • Farve: : lys eg
    • Delefrekvenser: 4 kHz
    Sub
    Velodyne spl1200r
    Driver: 12" forward firing (9.7" piston diameter) Die-cast aluminum basket
    "ERS" Class "D" Amplifier: 2000 watts Dynamic 1000 watts RMS Power
    Digital Auto Room Bass EQ: Yes
    Frequence Response: 22 - 120 Hz +/- 3 dB
    Digital Dynamic Driver Control with Current-Sensing Servo: Yes
    Digital Phase: 0, 90, 180, 270 degrees
    Low Pass Crossover: 40 Hz-120 Hz (adjustable) (12 dB octave, 24 dB ultimate)
    Auto On/Off: Yes
    Magnet Structure: 346 oz. (21.6 lbs.)
    Voice Coil: 3" inside/outside voice coil
    Inputs: Gold plated line-level and speaker-level
    Outputs: Line-level 80Hz up
    Crossover Bypass: Subwoofer Direct
    Cone: Kevlar-reinforced Resin
    Dimensions (H/W/D): (inc. feet, grill and knobs) 14.25" x 14.375" x 16.5" (37 x 36 x 41 cm) sealed
    Weight (approx.): 53 lbs. (24 Kg)
    TV
    Fujitsu/Siemens myrica v32-1
    gammelt men stadig dejligt tv hehe hverken full hd eller noget andet men det virker fint.
    Specs
    Visible screen diagonal 32 inch (81 cm) WXGA
    Panel resolution: pixels 1366 x 768
    Picture size: 603 x 336 mm
    Brightness typical: 550 cd/m²
    Contrast typical: 1000:1
    response time: 8 ms
    Electrical values External AC adapter
    Rated voltage 100-240 V
    Frequency 50-60 Hz Power draw
    Operating typical 155 W
    Standby mode < 5 W
    Playstation 3
    Denne brues til film musik og det hele. Det er den bedste invistering jeg har lavet. Der køre et optisk kabel fra ps3 til min dpr2005 og det funker bare. Efter jeg fandt ud af at jeg kunne lave en medieserver fra min pc til min ps3 køre alt denne vej hvad musik angår. Det er en uhygglig dejlig kvalitet
    til at styre det hele har jeg en logitech harmoney one. Har ikk lige fået taget noget billed og ved ikk lige helt hvad den kan men den er dejlig så man slipper for alle de fjernbetjninger
    så til billederne:
    Her har vi hele fronten
    Her har vi så kraftværket min elsket harman kardon dpr2005 det enste jeg savner er hdmi ind og udgange
    Min elsket ps3
    Mine fronter og center uden stof på.
    Bag ht med og-
    og uden stof
    Nærbilled af diskanten på den ene af mine bag ht
    Og
    lige et nærbilled af kevler mellemtonen på den ene baght
    og lige sub med og-
    og uden stof. lig mærke til kabelbakken på panelet så der er nul kabel rod
    Til sidst et billed bag hele kernen for at vise at jeg har prøvet at skjule kablerne bedst muligt. Der er skillespor i kanalen så man undgår emc
    det var det... Ris og ros modtages gerne
    Mit Set up
    Til top Vis ZanioN's Profil Søg efter andre indlæg skrevet af ZanioN
    Ole_M
    Tidl. The Elite
    Bruger siden: 18 Februar 2007
    Sendt: 29 November 2009 kl. 22:40 | IP-adresse registreret
    Fint system mester.
    Har du prøvet at flytte lidt rundt på dine fronthøjttalere, så det hele ikke står så kompakt? Det kan du vinde meget ved lydmæssigt.
    Til top Vis Ole_M's Profil Søg efter andre indlæg skrevet af Ole_M
    ZanioN
    Sendt: 29 November 2009 kl. 22:42 | IP-adresse registreret
    det er nok lidt svært at se på billederne men de kan ikk rigtig flyttes lige til venstre for der står skabene... men har prøvet og ja det giver en klart fordel... men bor stadig hjemme så må nøjes :( glæder mig til at få mit eget rum til anlægget
    Mit Set up
    Pierre
    Bruger siden: 28 Januar 2005
    Sendt: 29 November 2009 kl. 22:43 | IP-adresse registreret
    Fine komponenter osv. Men det er dog nok den mest klemte opsætning jeg nogensinde har set
    Dine fronter og center står jo side om side og spiller lige ind i din seng. Dine bagkanaler ser ud somom at de spiller foran din lytte pos. (vist du sidder op ad vægen).
    Så jeg ville helt klart gøre noget ved opsætningen
    Vin & Vinyl
    Ole_M
    Tidl. The Elite
    Sendt: 29 November 2009 kl. 22:45 | IP-adresse registreret
    Ah kan jeg se. Men lidt kan de da alligevel. Få cm. kan gøre rigtig meget. Hvordan klarer din Harman/Kardon det? Det ser ikke ud som om den har for meget effekt at gi af. Dine B&W 604ére kræver jo temmelig meget ved jeg.
    ZanioN
    Sendt: 29 November 2009 kl. 22:53 | IP-adresse registreret
    den klare det faktisk over alt forventning... kommer fra stereo med b&w'erne og en nad c372 så var selv nervøs... men den klare det rigtig godt kan spille rigeligt højt og rent... men på sigt når jeg flytter ud af lejligheden skal der en effekt på :D
    Mit Set up
    Ole_M
    Tidl. The Elite
    Sendt: 29 November 2009 kl. 22:59 | IP-adresse registreret
    Har den logic7? Meget fedt... Hvor mange watt er den opgivet til?
    ZanioN
    Sendt: 29 November 2009 kl. 23:01 | IP-adresse registreret
    120 watt per kanal og ja den har noget logic 7 men har aldrig brugt det og aner ikk hvad det er andet end det er et lydformat
    Mit Set up
    Ole_M
    Tidl. The Elite
    Sendt: 29 November 2009 kl. 23:03 | IP-adresse registreret
    Det skal du da ta og bruge. Lexicon bruger det også og det fungerer bare  Troede faktisk kun det var Lexicon der havde det, og det var deres lydformat - åbenbart ik. Men jeg vil da råde dig til at køre med det permanent.
    ZanioN
    Sendt: 30 November 2009 kl. 21:50 | IP-adresse registreret
    jeg syntes ikk det er så imponerende igen... har testet det siden igår og syntes ikk det er så fedt
    Mit Set up
    sonny73
    Bruger siden: 01 August 2009
    Sendt: 01 December 2009 kl. 01:50 | IP-adresse registreret
    dine højtelere stå godt nok tet på hinender... der må være svert at skille de lyd der komer fra de diverse højtelere for at få optimale souround lyd... ... har du overvejet at vende de baghojtelere på hoved ...da jeg ville umildbart mine at den lyd du høre fra dine baghøjtelere er reflektion fra den mur bag front højtelere... og der er ikke oprimel
    men alt i alt en fin lille set op
    Til top Vis sonny73's Profil Søg efter andre indlæg skrevet af sonny73
    BrAvO
    Bruger siden: 22 April 2004
    Sendt: 01 December 2009 kl. 21:24 | IP-adresse registreret
    Nice setup
    Til top Vis BrAvO's Profil Søg efter andre indlæg skrevet af BrAvO
    nemligja
    Bruger siden: 18 August 2005
    Sendt: 01 December 2009 kl. 21:46 | IP-adresse registreret
    Det er Harman koncernen der ejer Lexicon så der er forklaringen på at Harman også bruger det i egne "almindelige" recievere
    Panasonic 42 PX74, H/K 635 reciever, Pioneer dvd 600, Pioneer 433 dvd optager, SA 1550, SA 520 og SA talent, SA 200 SUB
    Til top Vis nemligja's Profil Søg efter andre indlæg skrevet af nemligja Besøg nemligja's Websted
    Hurin
    Bruger siden: 29 April 2006
    Sendt: 10 December 2009 kl. 10:02 | IP-adresse registreret
    Det er da nydeligt udstyr, men det kunne da helt klart trænge til at der kom en meter mere mellem de enkelte komponender.
    Jeg tror du ville få en bedre oplevelse med et sæt stax ørebøffer.
    Til top Vis Hurin's Profil Søg efter andre indlæg skrevet af Hurin
