Tilbage til HIFI4ALL.DK 18. juni 2026 | 22:34
Pladespillere
Emne Emne: lenco lovers (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
krenzler
Sendt: 04 Februar 2009 kl. 17:32 | IP-adresse registreret
Sjovt nok forsvandt den originale Home Despot tråd på næsten 100 sider hos AudiogoN også pludseligt engang (kører nu videre som version II). Konspirations-teorier er nu altid de sjoveste.
heffehurtig
Bruger siden: 22 Februar 2006
Sendt: 05 Februar 2009 kl. 20:43 | IP-adresse registreret
Det er godt nok stenet, at sitet bare, puf, forsvinder. Jeg var i korrespondence med en unævnt, men meget aktiv, bruger derindefra, som fortalte, at han var midt i en disputs med 'Chefen'. Over hvad, ville han ikke fortælle og jeg spurgte heller ikke. Men det kan da virke mærkeligt, især når der i øvrigt ikke give nogen som helst advarsel.
I hvert fald skidesynd!
Jeff
Til top Vis heffehurtig's Profil Søg efter andre indlæg skrevet af heffehurtig
krenzler
Sendt: 12 Februar 2009 kl. 15:51 | IP-adresse registreret
Seneste fra Lenco Heaven Forum:
"Dear lenco.proboards Member,
The mod team have been extremely heartened by the response to the new Lenco forum at Proboards.com. We have close to 200 members in less than two weeks.
However, there are a few issues with this forum that concern us:
1. We are not able to back-up and move off board this forum and worry about another Lenco community wipeout
2. The address, lenco.proboards.com, is not ideal given the obvious popularity of the site
3. Keeping adverts off the forum is proving expensive - we used up $7 in one week
4. We have not as much control and flexibility as we would like in order to provide a fitting place for our Lenco community
In an effort to tackle these issues we have decided that the best option for the long-term benefit of the Lenco Community on the net is to move new 'premises'. At the moment we are busy setting up what is a much nicer, more user friendly and easily backed-up forum at a new address. We will be anouncing exactly where in the near future.
This initial message is just to inform you all of the changes and you need to do nothing yet. However, there are a couple of things you should be aware of:
1. You will have to re-register at the new forum
2. Moving content is possible but it will be a cut and paste manual process so we suggest you hold back on posting new stuff you want to keep.
3. We will keep lenco.proboards open for a couple of weeks after the move to allow you to transfer posts over. This process is quite simple - as author you have access to a "modify" button in your own posts. If you click on that and copy the contents you will be able to paste into a new post at the new site with links to photos etc in tact.
We will be in touch again soon to keep you up to date. In the meantime if you have any questions please post on the forum in the news section of members' only rather than replying to this email.
Yours in Lencos,
the mod team."
Mellemhjulet
Bruger siden: 07 April 2006
Sendt: 12 Februar 2009 kl. 20:30 | IP-adresse registreret
Det ser da ud til at moderator gruppen og Francois er blevet uenige om et eller andet? Der er meget stille omkring det, lidt mistænkeligt.
Anyway, de er vist ved at flytte til http://www.lenco-heaven.co.uk/
Men Lenco er da heldigvis stadig sjovt at lege med
krenzler
Sendt: 16 Februar 2009 kl. 17:31 | IP-adresse registreret
Lenco Heaven (ny adresse).
santashooter
Bruger siden: 08 Januar 2008
Sendt: 17 Februar 2009 kl. 08:55 | IP-adresse registreret
noget der undrer mig, er at Francois overhovedet ikke er nævnt, og han har ingen finger med i spillet overhovedet...
"the gang of twelve" som styre det nye forum:
Andy,
Gary (azgary)
Eng Bo (B52)
Colin
David (Diawok)
Damian (dmar)
Ian
Mario
Peter (reinderspeter)
Scott (rfgumby)
Piero (Ropie)
Malcolm (willbewill)
selvfølgelig er det rart at en ny lenco kilde er født, men der er noget vedr. lukningen af lenco-lovers og francois som virker mærkeligt... han er ikke engang på medlems-listen...
men hvis manden har mistet lysten til lencoer, så fred med det...
det virker stadig bare mærkeligt.
mvh.
Søren
Mit setup
Til top Vis santashooter's Profil Søg efter andre indlæg skrevet af santashooter
<< Forrige Side af 2
