Tilbage til HIFI4ALL.DK 19. juni 2026 | 15:41
Emne Emne: Pioneer stopper tv produktionen! (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
luis figo
Bruger siden: 26 Januar 2004
Sendt: 07 Februar 2009 kl. 13:51 | IP-adresse registreret
Så har Pioneer valgt at trække sig helt ud af produktionen af fladskærme. De har længe vist en skuffende udvikling i indtjening på trods af en global økonomisk vækst, finanskrisen ser nu ud til at give dødsstødet. Her er nyheden:
"DOW JONES NEWSWIRES
TOKYO (Nikkei)--Pioneer Corp. (6773.TO) will pull the plug on its loss-ridden television business and shift its DVD player operations to a new venture with Sharp Corp. (6753.TO) in a sweeping overhaul, The Nikkei reported in its Thursday morning edition.
The company had been planning to end in-house production of plasma panels by the end of March and outfit its TVs with Panasonic Corp. (6752.TO) panels instead. Faced with worsening profit margins, however, it has decided to end TV development and production altogether.
Pioneer will idle its lone domestic TV factory in Shizuoka Prefecture sometime this year. Factories in the U.S. and Europe are already slated for closure.
Sales of Pioneer TVs will continue for the time being. The company has not yet decided what to do when inventories run out.
Meanwhile, Pioneer will spin off its DVD player operations, which are equally steeped in losses, to a new company to be set up with Sharp as early as this spring.
The company plans to eliminate several thousand of its roughly 40,000 groupwide jobs in the year ending March 2010. Pioneer is likely to post a consolidated net loss of more than Y100 billion for the year ending this March, wider than the Y78 billion loss it forecast earlier. "
Kilde: http://www.avforums.com/forums/plasma-televisions/930567-pio neer-end-tv-production.html
Selv om Pioneer stopper vil det stadig være en hård tid for alle de andre producenter. Konkurrencen er hård og denne finanskrise (økonomisk krise) er ikke overstået.
Jeg er stadig glad for mit Pioneer plasmatv, og skal man tro på noget af det feedback der har været fra CES 2009 messen vil de andre mærker stadig ikke kunne matche Pioneer Kuro serien før i 2010 eller senere, kun på kontrasten vel og mærke.
Dette betyder vel også at Panasonic overtager tronen som leverandør af de bedste plasma tv?
Til top Vis luis figo's Profil Søg efter andre indlæg skrevet af luis figo
l´Blundt
Sendt: 07 Februar 2009 kl. 14:03 | IP-adresse registreret
Det er da smadder ærgerligt De laver jo ellers noget de andre kun drømmer om. Men så er det da godt man har anskaffet sig et før de bliver umulige at opdrive.
Mvh. l´Blundt
velkommen
Bruger siden: 24 Oktober 2003
Sendt: 07 Februar 2009 kl. 14:38 | IP-adresse registreret
lidt uhyggelig læsning...men udvikling går jo stærkt på dette feldt....så mon ikke der dukker noget spændende op?????
har dog selv fået fat på to pioneer plasma.....så er vel kørende i nogen år...måske derfor de har været prissat så højt...de skulle vel lige have de sidste dollars med....deres prispolitik kan jeg ikke følge....
mvh Velkommen
floe
Bruger siden: 07 Maj 2007
Sendt: 07 Februar 2009 kl. 14:50 | IP-adresse registreret
MR = MC
Pierre
Bruger siden: 28 Januar 2005
Sendt: 07 Februar 2009 kl. 15:24 | IP-adresse registreret
Tjaaa er det nu jeg skal komme med en kommentar a la dem som kom i tråden  Har B&O en fremtid
Nej det lader jeg vær med, da jeg ikke vil væren en  som så mange andre
Vin & Vinyl
lexus
Bruger siden: 26 Januar 2006
Sendt: 07 Februar 2009 kl. 15:30 | IP-adresse registreret
 læste et sted at panasonic er 4 milliarder dollars
nede  ...skrider det hele????
jensen
Tidl. Vassago Hifi
Bruger siden: 01 April 2003
Sendt: 07 Februar 2009 kl. 15:38 | IP-adresse registreret
Synd de laver det bedste.
Så må man heller købe nogle il at have på lager for LCD kommer aldrig ind her.
Weissbier
Bruger siden: 11 Marts 2008
Sendt: 07 Februar 2009 kl. 16:11 | IP-adresse registreret
Den er god nok. Panasonics satsning på fjernsyn går også skidt. Salg under det forventede osv. Læste det i JP Erhverv. Måske man skal skynde sig, hvis man ønsker sig et plasmafjernsyn...
Martin Hinge
Lyngdorf TDAI 2200 RP
Denon DCD-3300/DVD-3800BD
Pioneer CT-959/PDR-555RW
Thorens TD 318 Mk III
Samsung PS64D8005
Dali Helicon 300 mk II
Beyerdynamic DT 770/DT 880
Kimber 4TC/8TC
Til top Vis Weissbier's Profil Søg efter andre indlæg skrevet af Weissbier
RogueAgent
Bruger siden: 09 Januar 2004
Sendt: 08 Februar 2009 kl. 00:32 | IP-adresse registreret
Prispolitikken er vel meget enkel - de prissætter dér hvor der er størst mulig indtjening. Når efterspørgslen daler for high-end produkter som den gør i det øjeblikkelige marked, så er valget reelt mellem at sælge med tab, eller gå på kompromis med kvaliteten for at kunne lave penge ved den pris markedet er villig til at betale.
Jeg synes det er superærgerligt hvis et mærke som Pioneer forsvinder fra fladskærmsmarkedet - men jeg synes det havde været værre hvis de for at overleve var begyndt at producere billigt bras som alle andre, og dermed alligevel skyde deres eget renomme i sænk.
Pioneer VSX-859 - Carver 753x - Energy RVS - Technics SL-1210mkII/Denon DL110 - Panasonic BD35 - Toshiba HD-XE1 - Pioneer CLD-D704 - LG 50PS8000 - Panasonic AE500
lexus
Sendt: 09 Februar 2009 kl. 16:14 | IP-adresse registreret
 nogle der har nyt i sagen...evt om salget
 i danmark....?
brasch
Bruger siden: 29 Oktober 2006
Sendt: 10 Februar 2009 kl. 19:10 | IP-adresse registreret
nogle andre medier har vist skrevet at pioneer overvejer hvad de skal
Fars er bedst når mor rør den
Sune Thomsen
Bruger siden: 23 Juni 2006
Sendt: 10 Februar 2009 kl. 22:11 | IP-adresse registreret
Og her stod jeg liger og overvejede at opgrader til Pioneer :(
ØV øv øv
Til top Vis Sune Thomsen's Profil Søg efter andre indlæg skrevet af Sune Thomsen
brasch
Sendt: 11 Februar 2009 kl. 12:34 | IP-adresse registreret
ØV øv øv
så er det da netop nu du skal gøre det
Sune Thomsen
Sendt: 11 Februar 2009 kl. 12:46 | IP-adresse registreret
brasch skrev:
ØV øv øv
Ja men venter på at få min restskat udbetalt :(
Og der kan godt gå lidt over 1 mdr endnu...
brasch
Sendt: 11 Februar 2009 kl. 12:54 | IP-adresse registreret
Sune Thomsen skrev:
brasch skrev:
ØV øv øv
så vidt jeg ved har de ikke lukket fabrikken endnu, men kører vist året ud
Sune Thomsen
Sendt: 11 Februar 2009 kl. 15:51 | IP-adresse registreret
brasch skrev:
Sune Thomsen skrev:
brasch skrev:
ØV øv øv
Ah nice, se så kan det måske nåes endnu :D
Weeeee.....
søren N
Bruger siden: 25 April 2006
Sendt: 11 Februar 2009 kl. 15:57 | IP-adresse registreret
Hva snaker du om Floe???
"Musikken frem for alt"
Mit Anlæg, kig forbi
Er du hifi-kræsen?
stengård
Bruger siden: 14 Januar 2009
Sendt: 12 Februar 2009 kl. 10:26 | IP-adresse registreret
ifølge financial times (som jeg uheldigvis kom til at oprette en tråd om - sorry) - stopper de med TV i marts 2010... Så der er jo nok tid nok - og
mon ikke der bliver et restlager-salg i efteråret ? Mange vil være bekymrede (med urette sikkert) over service og reservedele o.s.v.
Hav en god dag... med mindre du har andre planer
Til top Vis stengård's Profil Søg efter andre indlæg skrevet af stengård
Sune Thomsen
Sendt: 12 Februar 2009 kl. 12:42 | IP-adresse registreret
Så har jeg lige bestilt et LX5090H :)
Rasmus Larsen
Flatpanels.dk
Bruger siden: 05 September 2005
Sendt: 12 Februar 2009 kl. 16:38 | IP-adresse registreret
Det er super ærgerligt.
Men ja, det forholder sig sådan, at det er gældende efter marts 2010. Herefter ydes der dog naturligvis service og garanti.
Pioneer ændrer også en del andre ting i deres organisation. Læs mere her: http://www.flatpanels.dk/nyhed.php?subaction=showfull&id =1234444171
www.Flatpanels.dk - Guide til fladskærme
Til top Vis Rasmus Larsen's Profil Søg efter andre indlæg skrevet af Rasmus Larsen Besøg Rasmus Larsen's Websted
