Tilbage til HIFI4ALL.DK 6. juli 2026 | 05:35
Emne Emne: hjælp til forståelse af spec. på forstærk (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Christian Jense
Bruger siden: 12 Maj 2006
Sendt: 29 Juni 2007 kl. 12:04 | IP-adresse registreret
Hej.
Jeg går og kigger efter en ny forstærker. Da mine højtalere skal bruge en del kraft har jeg valgt at kigge på noget PA. Forstærkeren jeg har kigget på er en Mackie M2000, men for at kunne sammenligne den med andre på markedet vil jeg gerne vide hvilke spec. jeg skal kigge efter for at vurdere hvor rent forstærkeren spiller?
Spec. på forstærkeren er her:
M-Series Specifications
M•2000 M•3000 M•4000
Continuous Average Output Power in watts, both channels driven
20 Hz-20 kHz into 8 ohms per channel 325
20 Hz-20 kHz into 4 ohms per channel 525
40 Hz-20 kHz into 2 ohms per channel 800
Bridge Mono: 20 Hz-20 kHz into 8 ohms 1050
Bridge Mono: 40 Hz-20 kHz into 4 ohms 1600
Maximum Output Power in watts, both channels driven
1 kHz @ 1% THD into 8 ohms per channel 400
1 kHz @ 1% THD into 4 ohms per channel 650
1 kHz @ 1% THD into 2 ohms per channel 1000
Bridge Mono: 1 kHz @ 1% THD into 8 ohms 1300
Bridge Mono: 1 kHz @ 1% THD into 4 ohms 2000
If driving highly reactive loads, we recommend that the limiter circuit be engaged.
Power Bandwidth (rated power into 4 ohms):
20 Hz to 20 kHz
(Output power typically –3 dB at 50 kHz. Amplifier protection circuits
typically mute the output signal above 40 kHz at full power.)
Frequency Response (1 watt into 8 ohms):
< 10 Hz to 55 kHz (+0, –3 dB)
Distortion:
THD, SMPTE IMD < 0.05% @ 8Ω
< 0.10% @ 4Ω
< 0.20% @ 2Ω
Signal-to-Noise Ratio:
> 107 dB below rated power into 4 ohms
Channel Separation:
> 80 dB @ 1 kHz
Damping Factor:
> 500 (8 ohms @ 400 Hz)
Input Impedance:
24 kΩ balanced
12 kΩ balanced
Input Sensitivity:
1.23 volts (+4 dBu) for rated power into 4 ohms
Gain:
M•2000 31.4 dB (37.3 V/V)
Maximum Input Level:
9.75 volts (+22 dBu)
Rise Time (8 ohms):
< 6 μs
Slew Rate:
M•2000
Voltage Slew Rate 50V/μs
Current Slew Rate 25A/μs at 2Ω
H-Switch Slew Rate 10-50V/μs (program dependent)
CMRR:
> 34 dB, 20Hz to 20kHz
Load Angle:
8(±jx) time independent at 8Ω
4(±jx) time dependent, T > 6 min. at 4Ω
2(1±jx) time dependent, T > 2 min. at 2Ω
Transient Recovery:
< 1μs for 10 dB overdrive @ 1kHz
Maximum Output Offset Voltage:
±50 mV
High Frequency Overload and Latching:
No latch up at any frequency or level.
High Frequency Stability:
Unconditionally stable driving any resistive or reactive load.
Turn On Delay:
3 seconds
High-Pass Filter:
150 Hz, 2nd-Order Butterworth
Low-Pass Filter:
Limiter Section:
Complementary Positive and Negative Peak Detecting
Indicators:
Power ON LED (in power switch)
6 meter LEDs per channel
SIG (Signal Present), –20, –9, –6, –3, OL (Overload)
CH 1 & 2
PROTECT LEDs, SHORT LEDs, OVER TEMP LEDs
AC Line Power:
U.S./Canada 120VAC, 60Hz
Europe 240VAC, 50Hz
Japan 100VAC, 50/60Hz
Korea 220VAC, 60Hz
(Factory configured)
AC Drop-out Voltage:
At approximately 65% of rated line voltage
Jeg håber der er nogen der kan hjælpe mig.
www.hifi4all.dk/forum/forum_posts.asp?TID=83620&KW
Til top Vis Christian Jense's Profil Søg efter andre indlæg skrevet af Christian Jense
Sendt: 29 Juni 2007 kl. 12:18 | IP-adresse registreret
Sammenlign i samme impedans og begge kanaler samtidig. Dæmpningsfaktor bør være så høj som mulig.
Når forstærkeren går fra 8 til 4 ohm hhv, 2 ohm skal effekten teoretisk fordobles, der sker dog ikke i praksis, men der bør være så stor effektforøgelse som muligt.
Mackie er nok ikke det bedste på markedet, men fint til prisen.
Du kunne også overveje at købe brugt, og gå efter noget Crown.
Christian Jense
Sendt: 29 Juni 2007 kl. 12:31 | IP-adresse registreret
Jeg har kigget på Crown, de forstærkere fra dem der ligger i mit buget, der er dæmpningsfaktoren 300 hvor den er 500 på mackien, samt noise to signal forhold er 107db på Mackien og 105db på Crown.
Et mere af mine krav er at blæseren er temperaturstyret så jeg slipper for at høre på den når jeg en sjælden gang ikke spiller højt, eller når jeg ser film.
Sendt: 29 Juni 2007 kl. 13:34 | IP-adresse registreret
Hvorfor ikke gå efter en klasse D forstærker, så slipper du helt for blæserstøj.
Christian Jense
Sendt: 29 Juni 2007 kl. 13:37 | IP-adresse registreret
Jo men kan jeg få noget der levere minimum 400Wrms til en nypris omkring de 3500-4000kr? jeg er ikke så meget for at købe brugt nemlig.
Men hvad er det lige ved D-klasse forstærkere som er godt frem for en AB-klasse forstærker som Mackien?
Sendt: 29 Juni 2007 kl. 13:54 | IP-adresse registreret
Til max 4000 kr bliver det nok svært at få en klasse D forstærker med 400 watt i 8 ohm.
Klasse D har den fordel at de ikke vejer særligt meget, og ofte har rigtigt godt styr på bassen.
Prøv at kigge på Digiamp 2000.
http://www.cadaudio.dk/hififorst.htm
Bradman
Bruger siden: 21 Juli 2005
Sendt: 29 Juni 2007 kl. 13:56 | IP-adresse registreret
Hej....
Som udgangspunkt, så vil jeg få efter en crown....evt. som ny. Prøv den hos "Åge"....aftale noget returret. Om dæmpningsfaktor er 107 eller 105 db betyder ikke noget. Det er papir-data som ikke altid fortæller sandheden.
Der er flere hifi-entusiaster som har taget Crown til sig, så jeg tror der er noget om det. Hvis det er til dine Vega´er, så er store højttalere jo lettere at drive end små.....så selv med en mindre amp bør du kunne spille op.
Alt det der limiter/andre gimmicks trækker altså ikke lydkvaliteten op.....kun ned. Hvis du kun har 8m2 (som der står i din profil)....så er jeg tæt på sige det er ligemeget hvad du vælger, du vil alligevel ikke kunne høre en skid.
Christian Jense
Sendt: 29 Juni 2007 kl. 15:19 | IP-adresse registreret
Kjeldsen de forstærkere de har der inde er det ikke kun selvbygger forstærkere? og hvad med køling? de skal vel have et eller andet til at køle sådan nogle store forstærkere af med.
Det er ikke 400W 8 ohm jeg skal bruge men bare 400W i 4 ohm.
Jeg er god til elektronik, men jeg vil nu helst have noget der er anerkendt inde for enten PA eller hifi verdenen. forstået at jeg gerne vil være 100% sikker på at det er noget der virker og også virker længe. selv om jeg behandler mit udstyr godt, så skal det helst kunne holde i en del år.
Det med Crown, der syntes jeg ikke at det fremgår at blæserne er temperaturstyret, det er sådan set et af de største krav da det er en af de største grunde til at jeg skifter forstærker. den jeg har nu står nemlig som den gjorde den dag jeg fik den.
Sendt: 29 Juni 2007 kl. 15:51 | IP-adresse registreret
De fås både som byggesæt og færdigsamlet. Der første model har jeg selv, og der skal slet ingen køling til. de andre modeller kræver dog lidt køleplade men ikke meget. Det hele er med i byggesættene. Fordelen ved klasse D er netop at de næsten ikke afleder varme.
