Tilbage til HIFI4ALL.DK 6. juli 2026 | 09:32
Emne Emne: hjælp til justering af hz deling (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
ZzZzleepY
Sendt: 21 Juni 2007 kl. 16:02 | IP-adresse registreret
Hejsa
jeg er ikke 100% sikker på det er den rigtige del af forumet denne her kommer under...
og jeg er heller ikke 100% på om overskriften er rigtig...
men jeg ville høre om nogen kunne give mig nogle  grund regler for hvor man deler
bas / mellem / diskant
jeg har følgende udstyr og her er lidt detaljer om det...
B&W ASW 650 Subwoofer
Freq. Response-3dB 25Hz – 33/150Hz adjustable (EQ at A)
Freq. Range-6dB 20Hz – 40/180Hz adjustable (EQ at A)
Drive UnitsUnit 1: 300mm (12 in) dia paper/Kevlar® cone long-throw
Unit 2:
Unit 3:
FinishCabinet: Black Ash or Sorrento (light oak) vinyl
Grille: Black Cloth
Sub Woofer AmplifierDescription: Class B
Power Output: 200W continuous
Rated Power Consumption: 280W
Input Impedance: 22k ohms
Signal Noise: 90dB
Functions: Volume level - Low-pass filter frequency - Low-pass filter bypass - Bass roll-off alignment - Phase 0/180 - Auto sense on/standby
Inputs: Line In (RCA Phono)
Speaker Level In (binding posts)
Outputs: Line Out (RCA Phono, high-passed)
Link Out (RCA Phono, parallel to Line In)
Speaker Level Out (binding posts, high-passed)
Low Pass FilterActive 2nd-order, variable cut-off frequency
High Pass FilterLine level: Active 3rd-order at 80 Hz
Speaker Level: Passive 1st-order at 80Hz into 8 ohm resistor
(Response of passive filters dependent on load impedance)
B&W DM604 S3
Freq. Response39Hz - 22kHz ± 3dB on reference axis
Freq. Range-6dB at 30Hz and 42kHz
Sensitivity90dB spl (2.83V 1m)
Normal Impedance8 ohms (minimum 3 ohms)
Power Handling25W - 200W into 8 ohms on unclipped programme
Drive UnitsUnit 1: 1x 25mm (1in) metal dome high-frequency
Unit 2: 1x 180mm (7in) woven Kevlar® cone midrange
Unit 3: 2x 180mm (7in) aluminium cone bass
Grille: Black Cloth
DispersionDescription: Within 2dB of response on reference axis
Horizontal: over 40° arc
Vertical: over 10° arc
Harmonic Distortion2nd & 3rd harmonics<1% 42Hz - 20kHz (90dB spl, 1m)
Crossover Frequency450Hz, 4kHz
Max. Recommended Cable Impedance0.1 ohms
hvis nogen kunne oplyse hvor det ville være smartest at dele hz på følgende kunne det være super.. syntes det er lidt svært at finde ud af  :)   på forhånd mange tak
ps det er til musik og film
savner generelt at bassen er mere kontant og ikke buldre så meget.. men det er måske et spørgsmål om at vi ikke har nok møbler osv i rummet endnu ej heller gulvtæppe men trægulv
WWW for at se Min anlæg's tråd.
HD Medie Center
5.1 B&W DM600 top model(er) s3 serie
SONY Reciever / Aoc LCD Tv
Til top Vis ZzZzleepY's Profil Søg efter andre indlæg skrevet af ZzZzleepY Besøg ZzZzleepY's Websted
