Tilbage til HIFI4ALL.DK 27. juni 2026 | 08:07
Emne Emne: SACD DISC. (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
winter
Sendt: 22 Oktober 2004 kl. 10:22 | IP-adresse registreret
Hejsa.
Hvor mange forskellige sacd disc findes der.Jeg ved der findes singel layer og dual layer findes der flere typer?
Og hvad er forskellen?.
MVH
Bender
Eget valg!
Bruger siden: 14 September 2004
Sendt: 22 Oktober 2004 kl. 10:42 | IP-adresse registreret
Jeg har fundet følgende som beskriver det meget godt synes jeg
1.  SACD Stereo
2.  SACD Stereo + CD Audio
3.  SACD Stereo + SACD Surround Sound
4.  SACD Stereo + SACD Surround Sound + CD Audio
  • Surround Sound & SACD Stereo: SACD is able to offer ultra-high sound quality in comparison to CD, because the storage technology for SACDs holds more than four times the amount the information than the equivalent for the CD format.
    The information can be stored in up to 8 separate channels: two for SACD Stereo Sound and up to six for Surround Sound. DG is using both "5.1 -" and "5.0 Surround Sound", which means that there are five fully used channels plus one extra sub-woofer channel focused exclusively on the playback of bass frequencies, if judged to be necessary.
  • Hybrid SACDs: DG's first set of releases are, all but two, hybrid SACDs, including both SACD Surround Sound and SACD Stereo as well which means that the discs include an additional CD layer, allowing playback on current CD players at current CD sound quality.
    The following two releases, Bernstein / West Side Story (471 631-2) & Thielemann / Alpine Symphony (471 636-2), are both examples however, of non-hybrid SACDs - i.e. these discs will not include the CD layer for CD playback capability. But they include both Surround Sound and SACD Stereo possibilities.
    In the future, we are planning to release all types of SACDs as in the diagram above.
  • The technology: SACD uses Direct Stream Digital (DSD) a 1-bit recording technology in conjunction with the SACD itself. The technique claims frequency response of over 100kHz and a dynamic range of over 120dB across the audible frequency range.
    According to Sony and Philips, DSD increases the resolution of music by the ability to follow the original wave form of the music more closely. This results in music reproduction that is remarkably pure and faithful to the original.
    Additional information: Please see the dedicated SACD websites of Philips and Sony for more detailed information.
    http://www.superaudio-cd.com/
    http://www.sacd.philips.com/intro.html
    (Hentet fra : http://www.deutschegrammophon.com/sacd/main.htms?PAGE=featur es)
  • __________________
    ... Intet lyder så dårligt at det ikke lyder godt for nogen...
    Til top Vis Bender's Profil Søg efter andre indlæg skrevet af Bender
    Vanderlay
    Sendt: 22 Oktober 2004 kl. 10:45 | IP-adresse registreret
    I modsætning til single layer, er der to lag på en dual layer-skive. Ok, ret intetsigende forklaring, men disse muligheder findes:
    De mest simple skiver indeholder kun stereo og kan kun afspilles på en sacd-afspiller. En sacd har altid dette spor, men i nogle tilfælde mere.
    Så kan den derudover indeholde eet eller begge af følgende spor:
    - et diskret multikanalspor (som regel 5.1 - men ind imellem færre kanaler)
    - et cd-spor, der kan afspilles på almindelige cd-afspillere.
    En sacd, der også har cd-spor, kaldes også en hybrid, og hvis der står 'hybrid multichannel' på skiven, har den altså alle tre.
    I enkelte tilfælde er der flere udgivelser af samme plade, fx. er Police-pladerne udgivet som ren SACD stereo i USA og som hybrider i Europa. Så det er værd at lægge mærke til de supplerende oplysninger.
    Udviklingen går imod, at flere og flere bliver udgivet som hybrider (men ikke uden undtagelser), og generelt kommer der også flere multichannel nu end i begyndelsen.
    Der findes vist omkring 2500 udgivelser i alt. www.sa-cd.net er et udmærket arkiv over de fleste, men beskrivelserne er af blandet kvalitet.
