Tilbage til HIFI4ALL.DK 26. juni 2026 | 19:29
Emne Emne: Hør effekten af de høje frekvenser (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Kurt von Kubik
Bruger siden: 14 Oktober 2003
Sendt: 03 Februar 2004 kl. 16:14 | IP-adresse registreret
Hejsa!
Se lige hvad jeg fandt på Analysis plus hjemmeside.
De 2 toner skal illustrere hvad der sker, når der tabes højfrekvens.
Prøv selv, selvom man vel næppe kan tale om HF på PCén. Det sjover er nemlig, at HF påvirker de lavere frekvenser meget.
Hvis knapperne ikke virker, så hop herhen: http://www.analysis-plus.com/Pages/soundclip.htm
Below are two sound clips, both of the same piano note.  One is the original note, the other has had much of the high frequency content removed. Comparisons of the two signals are shown in the plots below.
Press to hear original piano note
Press to hear piano note with HF removed
If we alter the frequency spectrum in a non-uniform way, we alter the harmonic content and hence the essential time waveform. We've changed the character of the music we hear.
Why are high frequencies important?
Although exaggerated for web purposes, these sound clips show what happens when sound data is lost.  This loss of high frequency information is one of the main reasons cables sound different.  Analysis Plus cables were specifically designed to minimize the loss of high frequency information, and that's why they sound better.
That's why Analysis Plus Hollow Oval cables sound better. Through the use of computer modeling, we've designed a cable through which the current distribution changes very little over the audio band. This means that the electrical properties of the cable, its resistance and inductance, don't change with frequency. The result is a cable that transfers the electrical energy from your amplifier to your speaker, without altering the time domain waveform of your music. You hear everything the musicians intended.
OceanMan
Bruger siden: 28 April 2003
Sendt: 03 Februar 2004 kl. 16:58 | IP-adresse registreret
Heyza...
Ja, selv på denne Dell bærbare kan jeg tydeligt høre forskel i de to toner, så det burde også være muligt i andre maskiner...!?
Men derfor burde deres kabler altså lyde bedre?? Eller hvad drejer det sig egentlig om....?!
Til top Vis OceanMan's Profil Søg efter andre indlæg skrevet af OceanMan
Kurt von Kubik
Sendt: 03 Februar 2004 kl. 18:04 | IP-adresse registreret
OceanMan skrev:
Heyza...
Hejsa Vandmand!
Ja!
Det er hentet fra et kabel firmas hjemmeside, men det gælder for den sags skyld for alle apparater også. Hvis HF tabes, så kommer man som her (overdrevet) til at mangle klarheden.
Det var såmænd det der var budskabet.
