Tilbage til HIFI4ALL.DK 8. juli 2026 | 23:16
Emne Emne: Godt køb? (LDC TV) (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Troels
Bruger siden: 21 September 2005
Sendt: 21 September 2005 kl. 10:26 | IP-adresse registreret
Jeg har fået tilbudt et brugt Prosonic LC-27M65 LCD TV:
2 års pixel garenti
PIP og POP = 2 tunere
Samlet i DK , da Prosonic stadig fik lavet hos Orion i pandrup
a.. Home LCD TV with 200-channel memory
a.. Automatic and semi-automatic station search features
a.. Manual fine-tuning
a.. LCD TV with program skip function
a.. OSD with multi language support
a.. Four adjustable picture and sound modes
a.. 27-inch LCD TV with auto power-off feature
a.. Child lock
a.. Sleep timer
a.. Top/Flof teletext
a.. LCD TV with full function remote control
a.. Picture in picture and picture on picture features
a.. Freeze picture feature
a.. Home LCD TV with five-band graphic equalizer
a.. Easy mounting with multiple mounting options
a.. Screen size: 27-inch
a.. Resolution: 1280 x 720pixels
a.. Pixel pitch (V x H): 0.51 x 0.51mm
a.. Display colors: 16.7million
a.. Contrast ratio: 600:1
a.. Brightness: 550cd/m²
a.. Power consumption: 140W
a.. Operating voltage: 100Vac to 240Vac at 50Hz to 60Hz
a.. Viewing angle:
 a.. Horizontal: 170°
 b.. Vertical: 170°
a.. Compatible TV systems:
 a.. PAL BG
 b.. PAL DK
 c.. PAL I
 d.. PAL MN
 e.. PAL/SECAM L
 f.. PAL/SECAM L'
 g.. PAL/SECAM BG
 h.. PAL/SECAM BG and DK
 i.. NTSC 3.58Mhz
 j.. NTSC 4.43Mhz playback
a.. Aspect ratio:
 a.. 4:3
 b.. 16:9
a.. Channel coverage:
 a.. VHF-1 channel 2 to 4 (S1 to S10)
 b.. VHF-3 channel 5 to 12 (S11 to S41)
 c.. UHF channel 21 to 69
a.. Connections:
 a.. HDTV inputs:
   a.. Video: Y - Pb/Cb - Pr/Cr
   b.. Audio: L/MONO, R
 b.. DVI audio/video input
 c.. D-SUB audio/video input
 d.. Two euro-scart input/output sockets
 e.. S-VHS input
 f.. VGA monitor input
 g.. PC audio input
 h.. RCA audio/video input/output
 i.. Headphone input
a.. Weight: 19kg
a.. Dimensions (W x D x H): 808 x 211 x 523mm
Skal jeg være opmærksom på noget specielt når jeg skal ud og kigge på det?
Jeg skal gi' 5000 kr. for det. Ser dette ud til at være et godt køb?
Troels
Til top Vis Troels's Profil Søg efter andre indlæg skrevet af Troels
kyhn
Bruger siden: 05 Februar 2004
Sendt: 21 September 2005 kl. 10:39 | IP-adresse registreret
hvis du syntes det er pænt og ikke har krav til billedkvalitet så kan det jo være godt nok! kunne finde til ca. 10.000 kr ny
http://www.dr.dk/konsum/test/fladskaerme.htm
Troels
Sendt: 21 September 2005 kl. 10:42 | IP-adresse registreret
Krav til billedekvalitet har jeg da, men når man ikke smider mere end 5000 efter et 720p HDTV så er det vel begrænset hvor store krav man kan stille.
kyhn
Sendt: 21 September 2005 kl. 11:20 | IP-adresse registreret
tja man kan vel altid stille krav
men faktisk så mener jeg at hvis man køber TV i denne kategori (billig og flad) så er det vigtigere hvordan Tvet ser ud uden billed på, da købsgrunden må være design.
dvs. billedkvalitet er sekundært, design primært.
(ellers så køb et godt 32" CRT)
zerocool
Bruger siden: 19 Maj 2004
Sendt: 21 September 2005 kl. 11:28 | IP-adresse registreret
Netop... så har du vel også svar. Spørgsmålet er så om du kan leve med billedkvaliteten fra et kr. 5.000,- Prosonic Lcd-Tv? 5.000 kr. er stadig mange penge for noget l**t.
Til top Vis zerocool's Profil Søg efter andre indlæg skrevet af zerocool
Troels
Sendt: 29 September 2005 kl. 21:18 | IP-adresse registreret
For lige at afslutte tråden. TV'et blev købt og det er faktisk overraskende pænt.
Billedekvaliteten er mere end tilfredsstillende med de signalforhold jeg lider under, så nu mangler jeg bare at få hængt det op. Måske i weekenden?
MeLVIS
Bruger siden: 19 Juni 2005
Sendt: 29 September 2005 kl. 22:38 | IP-adresse registreret
uha.. de prosonic jeg har kigget på når man var alligevel kiggede rundt omkring, har været utroligt dårlige.. Gode specs, men sygt dårligt billede...
50" HDTV, DENON, DALI Concept og Xbox 360 RuLeZ!!!
Til top Vis MeLVIS's Profil Søg efter andre indlæg skrevet af MeLVIS
