Tilbage til HIFI4ALL.DK 9. juli 2026 | 16:21
Emne Emne: goldring pu (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
bsl2
Bruger siden: 13 Februar 2004
Lokalitet: Øerne
Sendt: 21 Maj 2006 kl. 14:16 | IP-adresse registreret
hej alle
har i nogle erfaringer med goldring premium mc pu ell. goldrings andre mc-er evt elite
                                          mvh bsl2
Til top Vis bsl2's Profil Søg efter andre indlæg skrevet af bsl2
krenzler
Sendt: 22 Maj 2006 kl. 14:13 | IP-adresse registreret
Jeg har aldrig hørt om en "Goldring Premium". Den findes hverken på Goldrings hjemmeside eller hos "Cartridge Database"?
Er det en helt ny model eller er det måske en speciel Audio Note modificeret udgave af en Goldring?
bsl2
Lokalitet: Øerne
Sendt: 22 Maj 2006 kl. 17:25 | IP-adresse registreret
hej krenzler
det er også en fejl fra min side. den hedder selvfølgelig elite
                                           mvh bsl2
krenzler
Sendt: 24 Maj 2006 kl. 01:09 | IP-adresse registreret
Hej bsl2.
Du er på udkig efter en passende PU til din "The Foot" arm ikke? :-)
Jeg sendte en mail til aslgroup som er distributør af Nottingham Analogue i USA (tror jeg nok).
aslgroup
Her er det svar jeg fik:
"Hello Kim,
Sorry it took so long for me to add my humble words. As you can see by
Mike's comments below, Nottingham doesn't keep those sorts of specs. It's
only by threat or coercion that we get those sorts of numbers on current
items.
Tom Fletcher doesn't believe much in the value of those things, so those of
us who do must simply sit back and be glad he worries about the things he
focuses on that others forget.
So, what can I offer in the way of advice? Well, Tom is a firm believer
that people who go to the extreme in any direction usually lose the
important bits in the middle. That means that the arms tend towards the
middle of the spectrum in most parameters. It also means that they are
happiest with cartridges that are not too anything. Not too heavy, not too
light, not too compliant, not too uncompliant. We have found that they work
with a variety of mainstream cartridges, Benz Micro, Dynavector, Grado, Lyra
and others. One of our favorites is the Shelter brand. I am using a 90x on
my Decco/Anna combination and my partner has a 901 on his new Ace Space
table. While I do not have any experience on the Foot Arm in particular, I
do know Tom and I bet the sorts of things it likes to see from a cartridge
is not that different.
Of course you always have to stay aware of what's happening in the rest of
the system, the table never stands alone, but I bet you'd be happy with a
501 or a 901. What does your local dealer say? They could make a
recommendation based on your system and your listening environment.
Hope this helps, any further questions don't hesitate to e-mail back.
Bob"
Jeg ved ikke om du kan bruge det til noget? Jeg har før hørt at NA anbefaler Shelter PU'er så hvem ved?...
Phonophono - Shelter
Shelter 501 Mk II
Anmeldelse
Anmeldelse 2
Nu er det ikke fordi jeg er ude på at prakke dig noget på. :-) Jeg har ingen idé om hvorvidt en Shelter vil fungere i din arm...
Du har måske allerede investeret i en ny PU?
bsl2
Lokalitet: Øerne
Sendt: 24 Maj 2006 kl. 07:37 | IP-adresse registreret
hej krenzler
tak for infoen fra aslgroup. jeg var i lydbutikken i fredags og lytte til p77 og gradoen til 5000 men var ikke tilfreds med lyden i dem.problemet er også at p77 og de dyrer tekni-fi pu-er er udgået pga boron nålefanerne ikke kan skaffes mere. det er iøvrigt nottingham analog der laver alle tekni-fi pu-er.så dagen endte med en tur hos audioconsult.anders påpegede også det med at no er mørk i lyden. så han anbefalede en goldmund elite mc.den har jeg så monteret igår aftes.jeg skal nok lige vænne mig til lyden for den er noget anderledes end k1/3.den virker mere lys i toppen og slank i bassen.det er muligt at jeg skal justere på højtalerne.og steelhead har jo også en del muligheder så mon ikke det kommer til at virke efter et stykke tid. det er jo også det der er det sjove i ved vores hobby at få det til at spille
        mvh bsl2
hifijan
Dobbeltprofil!
Bruger siden: 06 April 2005
Sendt: 24 Maj 2006 kl. 08:48 | IP-adresse registreret
Hej bsl2...
Jeg er også blevet Nottingham Analogue fan, efter at ha' hørt et "Space deck" hos en kammerat med en billig k1 pick-up til 500,-...  jeg undre mig over, at man bruger så billig en pick-up til et så lækkert værk, men jeg må indrømme, at det virker..   Jeg ville gerne selv ha' et Space deck / Ace-Space arm / pick-up ??? ved jeg ikke, men max. kr. 5.000,- Desværre siger min pengepung at jeg skal beholde min Rega Planar 5 / RB700 arm /exact pick-up / TT PSU strømforsygning noget tid endnu, men min næste pladespiller hedder helt sikkert Nottingham Analogue
hvilket værk og arm kører du med...?
mvh. Jan
Holfi Pre NB1 S.E.
Holfi Power NB250
Lyngdorf CD-1
Rega Planar 5
Dali Euphonia MS4
Thule Spirit TU150 DAB/FM
Nakamichi LX-5 cass
Denon AVR-3803
Denon DVD-A11
Panasonic NV-HS900
Dali Rear 0.8
Til top Vis hifijan's Profil Søg efter andre indlæg skrevet af hifijan
bsl2
Lokalitet: Øerne
Sendt: 24 Maj 2006 kl. 10:13 | IP-adresse registreret
hej jan
en spacedeck m. heavykit og 12" the foot arm spiller jeg med.k1ogk3 pu-erne er rigtig gode der er lige kommet et nyt hus til dem jeg har kun hørt det hos lydbutikken så om det er bedre ved jeg ikke
                                                              mvh bsl2
hifijan
Dobbeltprofil!
Sendt: 18 Juni 2006 kl. 14:11 | IP-adresse registreret
Hej igen....
Efter en 'drømme' week-end, hvor drømmen er en Nottingham Analogue Hyper Space deck / Ace-Space arm / Grado Reference Master MM Pick-up til ialt kr. 39.000,-
- så landede jeg...  den får jeg nok aldrig... - men hvis jeg nu kunne få en fornuftig pris for min Rega Planar 5, så var en ikke helt umulig drøm Nottingham Analogue Interspace deck / Ace-Space arm / Grado Reference Master MM Pick-up  ialt kr. 23.000,-  ville det være en okay kombi...?
mvh. Jan
Holfi Pre NB1 S.E.
Holfi Power NB250
Lyngdorf CD-1
Rega Planar 5
Dali Euphonia MS4
Nakamichi LX-5 cass
Denon AVR-3803
Denon DVD-A11
Panasonic NV-HS900
Dali Rear 0.8
