Tilbage til HIFI4ALL.DK 20. juni 2026 | 02:24
Emne Emne: ribbon tweeter - monacor (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
gli-
Highend Sound
Bruger siden: 18 April 2003
Sendt: 02 Oktober 2006 kl. 20:49 | IP-adresse registreret
Har lige fået det nye fra Monacor, og hvad opdager jeg, en helt ny ribbon tweeter til hold nu fast 269 kr vejledende.
spec:
RBT-95
Varenummer: 102250
Finally, a ribbon tweeter (magnetostatic speaker) is available again from MONACOR:
modern appearance, of high power capability in exactly the right range of applications and with a perfect price-performance ratio.
Ribbon tweeter, 8Ω, 60WMAX, 30WRMS
This magnetostatic speaker of an exceptionally high efficiency achieves a perfectly fine dynamic reproduction of the high range and the brilliant range. The power capability of the system can considerably be increased by voltage dividers (level attenuations which take the RBT-95 down to the level of normal HiFi systems) and maybe higher crossover frequencies. This tweeter achieves a very light sound of low distortion which particularly improves the stereophony in applications from 5kHz on. By adding a super tweeter above 8-10kHz, e.g. even high-quality full range systems can be further improved with the RBT-95.
Technical datasheet
Impedance (Z)
Resonant frequency (fs)
4,500Hz
Max. frequency range
fx-22,000Hz
Rec. crossover freq. (12dB)
5,000Hz
Music power
> 60WMAX
Power rating
>ç30WRMS
SPL (1W/1m)
98dB
Voice coil diameter
Magnet diameter
Mounting cutout
80x45mm
Mounting depth
17mm
Dimensions
Ø 95mm
Weight
120g
soxen
Bruger siden: 21 Oktober 2004
Sendt: 02 Oktober 2006 kl. 21:07 | IP-adresse registreret
Har bestilt et par for at teste dem
| DIY Audio |
abj_eskimo
Bruger siden: 18 Marts 2004
Sendt: 07 Januar 2008 kl. 21:13 | IP-adresse registreret
Rusker lige lidt gang i tråden igen (nu må vi se om det lykkes..)
Er de blevet testet? Det kunne være interessant lige at høre din vurdering af enhederne..
Til top Vis abj_eskimo's Profil Søg efter andre indlæg skrevet af abj_eskimo
soxen
Sendt: 19 Januar 2008 kl. 22:14 | IP-adresse registreret
Nope desværre jeg solgte dem inden jeg nåede at lyttte til dem.
Måske har andre nu haft lejligheden til at lytte til disse bånd der har fået fine ord med på vejen i bl.a. Tyskland.
| DIY Audio |
soxen
Sendt: 17 Maj 2008 kl. 05:31 | IP-adresse registreret
Nogen der har haft lejlighed til at lytte til disse enheder???
http://www.monacor.dk/produkter/hoejttalerenheder-hifidiskan t/vnr/102250/
| DIY Audio |
