Tilbage til HIFI4ALL.DK 19. juni 2026 | 03:26
Emne Emne: Speakers for NAD C372 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
narayanar
Bruger siden: 14 April 2008
Sendt: 14 April 2008 kl. 12:03 | IP-adresse registreret
Hi
I am new to this forum, living in copenhagen. I bought a new Int. Amp NAD  C372. Could you please suggest me the best suitable speakers for my amp.
Thanks
Narayana
Til top Vis narayanar's Profil Søg efter andre indlæg skrevet af narayanar
FreZh
Ansat hos Dali
Bruger siden: 07 August 2004
Sendt: 14 April 2008 kl. 12:36 | IP-adresse registreret
Do you have ane preference for the speakers? Design, size etc.?
And what pricerange?
Til top Vis FreZh's Profil Søg efter andre indlæg skrevet af FreZh
Ascari
Bruger siden: 19 Juni 2004
Sendt: 14 April 2008 kl. 15:10 | IP-adresse registreret
What size is your room?
And what music do you like?
narayanar
Sendt: 15 April 2008 kl. 16:06 | IP-adresse registreret
Hi
I am not sure of size, but will be more than 15*20 feets. I dont have any preferences in speakers or sizes, but looking for Floor speakers.
I have to take them along with me to India next month.  I am staying in copenhagen, if i buy a new speaker i have to pay 30 to 40%tax(duty) while transporting to india. But in india i dont have many options.
Here i find many brands, i donno which one will suit NAD c372 best.
Could some one please help me out.
Initially i thought i can go for Dali Ikon 6, but now i am looking for better speakers.( I have no problem with used ones also).
Regards,
narayana
CosworthDriver
Bruger siden: 01 August 2007
Sendt: 15 April 2008 kl. 16:23 | IP-adresse registreret
Hello
Have you tried to listen to Audiovector speakers? A danish speaker company that makes top end speakers. http://www.audiovector.com/
If you buy a set of demo-speakers, do you then still have to pay tax (as they in therory are used)?
Right now the Audiovector MI3 series are replaced with a new series (called S3 series). So right now you can get the MI3 series cheaper, especially demo-sets.
Check these stores for demo sets:
http://www.topsoundhifi.dk/?layout=1
http://www.ktradio.dk/
You should bring your NAD amp to these stores and listen to the Audiovectors together with your amp.
Otherwise you can easily find a set of used Audiovector MI3's (or M3's which is the older series) on www.dba.dk or on the salespage here on hifi4all. http://www.hifi4all.dk/ksb/soegresultat.asp?annoncetype=& ;produkttype=&fritekst=audiovector&lokalitet
I guess danish speakers are very expensive in India, so I believe that it would be a good idea to bring a set of good quality danish speakers.
CosworthDriver
- "If everything seems under control, you're just not going fast enough" - Mario Andretti
Til top Vis CosworthDriver's Profil Søg efter andre indlæg skrevet af CosworthDriver
narayanar
Sendt: 15 April 2008 kl. 21:42 | IP-adresse registreret
Hi
Is audiovector better than dynaudio. Please let me know. how about the dynaudio contour 1.8...
rgds,narayana
CosworthDriver
Sendt: 15 April 2008 kl. 22:33 | IP-adresse registreret
narayanar skrev:
Hi
rgds,narayana
In my opinion, they are very close regarding buildquality and quality of the drivers. Regarding soundquality, I guess you'll have to listen to them yourself, as people have different taste in sound.
CosworthDriver
