Tilbage til HIFI4ALL.DK 26. juli 2026 | 14:55
Emne Emne: panny ae700 ny firmware update (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
kokken
Bruger siden: 05 Februar 2004
Sendt: 06 Januar 2005 kl. 11:42 | IP-adresse registreret
hej
er der nogle ved om det passer??
http://www.avsforum.com/avs-vb/showthread.php?s=9c574ffbf98b 4b898319b1cf8cedb2c7&postid=4927331#post4927331
I just found this on the regular thread for those who missed it. It seems like something is in the works at least as far as the white flash issue goes.
I hope they also come up with solutions for the other problems described
in this fourm such as cropping, peak a boo, and VB.
I think someone else posted that 105 also corrects the cropping issues but
I am not sure.
Does anyone know how to check the firmware version on the AE700?
"!!!!! SOME VERY IMPORTANT NEWS ABOUT WHITE FLASHES !!!!!
I have received a response from Panasonic Japan. They have found the solution! Their response:
Symptom: Appear the white flash and like snow noise at once per about 2 hors operation.
Causes: State of HDCP (High-bandwidth Digital Content Protection) will be changed due to the noise on the signal of transmitter (DVD, HDMI and Cable) and software design of AE700 was corresponded decryption transaction and it will be appeared as the snow noise about 60ms.
Countermeasure: Change/use to improved/corrected software version (version 1.05).
I have to send my PT-AE700 to Panasonic Swiss to update the firmware! "
fra avsforum
kokken
Til top Vis kokken's Profil Søg efter andre indlæg skrevet af kokken
kokken
Sendt: 11 Januar 2005 kl. 14:11 | IP-adresse registreret
   hej alle
 det er nu officelt, der er en ny firmware til vores panny ae700 fra virsion 1.03 til 1.05 eller var det nu 1.50 .
den skulle komme til danmark fra næste uge,vi kan takke alle dem på avsforum.
der har blevet ved med at punke panasonic, med white flash osv
i kan læse om den nye update her
http://www.avsforum.com/avs-vb/showthread.php?s=fb7fd8d7e592 01044d6652b47b718ba2&threadid=465849&highlight=hdmi
kokken
Kim Dahl
Bruger siden: 10 Marts 2004
Sendt: 23 Februar 2005 kl. 16:29 | IP-adresse registreret
Hvordan får man nemmest opgraderet firmware på sin AE700, nu når der er kommet en version 1.07
Til top Vis Kim Dahl's Profil Søg efter andre indlæg skrevet af Kim Dahl
kokken
Sendt: 25 Februar 2005 kl. 22:14 | IP-adresse registreret
hej
du skal kontakte din forhandler og han skal sende den ind til en update
kokken
Mox*
Bruger siden: 01 August 2004
Sendt: 28 Februar 2005 kl. 17:04 | IP-adresse registreret
Hvor finder man sådan en Panny i firmware-opdateret stand fra ny?
(og naturligvis til den bedste pris med levering igår)
Til top Vis Mox*'s Profil Søg efter andre indlæg skrevet af Mox*
kokken
Sendt: 28 Februar 2005 kl. 18:28 | IP-adresse registreret
Mox*
Sendt: 28 Februar 2005 kl. 19:31 | IP-adresse registreret
Takker
