Tilbage til HIFI4ALL.DK 8. juli 2026 | 08:47
Emne Emne: Thule IA60 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
JOE45
Bruger siden: 16 Januar 2004
Sendt: 18 Januar 2004 kl. 20:04 | IP-adresse registreret
Hello.
Sorry I can just english or french...
I want know do you think about the thule IA60 or IA100,I have a klipsch RF35 loudspeaker and I search a smooth and dynamic amplifier for this loudspeaker.
I think the thule IA60 is ok,what do you think?
Thank you very much/merci beaucoup
Til top Vis JOE45's Profil Søg efter andre indlæg skrevet af JOE45
jetz
Bruger siden: 03 November 2003
Sendt: 18 Januar 2004 kl. 20:19 | IP-adresse registreret
I have the IA100 I only have good things to say about this amp. Good smooth and bright sound. Fine bass too. Most of all it has very good drive capabillities. All in all it is a very 'able' amp. I guess that the ia60 has most of the same trades, but with i little less power.
Also be on the look for the IA60b, this amp is really underestimated if you ask me.
Hope this helps
Til top Vis jetz's Profil Søg efter andre indlæg skrevet af jetz
JOE45
Sendt: 19 Januar 2004 kl. 11:11 | IP-adresse registreret
Thank you for your answer
The klipsch RF35 is a litle too bright in the treble(horn),the thule is not too bright for the klipsch?
Wich loudspeaker do you have with the thule?
The IA60B is too expensive for mee...
I have a Denon A/V amplifier too,can I connect the front preout of denon in the main in
the thule,and connect a cd player on the CD input,and switch between normal and main in with the materiel powered on?
Thanks.
thomas_ls
Bruger siden: 14 April 2003
Sendt: 19 Januar 2004 kl. 11:16 | IP-adresse registreret
I would consider IA60 or IA60B, the way the new IA100 is build is not as it was years ago!!
The IA60B should be fantastic, I have not listened to it, but heard a lot about it
Til top Vis thomas_ls's Profil Søg efter andre indlæg skrevet af thomas_ls
thomas_ls
Sendt: 19 Januar 2004 kl. 11:19 | IP-adresse registreret
Loudspeaker!!
Go to KT Radio, street:  Vesterbrogade
There you can get System Audio SA1280 on sale! 10.000 -> 7000 pair.
That is value for money and then it is also nice designed
Ronin
Lyd og Billed Vodskov
Sendt: 19 Januar 2004 kl. 11:34 | IP-adresse registreret
JOE45 skrev:
Hello.
Hi there
If your funds are limited I would recommend you to be on the look-out for the older Thule IA100, the one with silver buttons, balanced inputs and temperature-indicator on the forntpanel. Technically it is superior to the newer and yet smaller models IA60 and IA100. Names can be decieving and the new IA100 has nothing to do with the old one. Tecnically the old one can be compared to the Thule IA150B - the main differences on these models are the extra watts and a revised layout. One of the best things about this amp is its ability to control the speakers, which is superior to new IA60 and 100 of today. And with a balanced cd-player the soundstage adds an extra class in dimensions!
Keep in mind though, that the "old" IA100 is difficult to find with remote control, but with a little bit of luck you should be able to find it on the market for used products. But if you don´t mind getting up when you need to change the volume, the IA100 is a 100% hit!
JOE45
Sendt: 19 Januar 2004 kl. 19:12 | IP-adresse registreret
How old are the old IA100?I think it was dificult for me to find the old models.
But the new models is good too?
Thanks for your help.
Mr. Diggler
Bruger siden: 23 Februar 2004
Sendt: 23 Februar 2004 kl. 02:12 | IP-adresse registreret
I've a Thule IA60 for sale!
Perfect condition, used for approximately 100 hours.
2500,- and it's yours!
If interested contact me at nikolaj@claimfame.dk
Nikolaj
Til top Vis Mr. Diggler's Profil Søg efter andre indlæg skrevet af Mr. Diggler
