Tilbage til HIFI4ALL.DK 13. juli 2026 | 06:29
Emne Emne: KEF 104/2 data (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Holmen
Bruger siden: 16 Maj 2006
Sendt: 10 August 2006 kl. 11:25 | IP-adresse registreret
Jeg har lige investeret i et sæt KEF 104/2, som jeg er overordentligt tilfreds med. Det eneste jeg er i tvivl om er størrelsen på bas-enhederne. Er de 6, 6,5 eller 8 tommer?
På forhånd tak.
Til top Vis Holmen's Profil Søg efter andre indlæg skrevet af Holmen
finn52
Bruger siden: 29 April 2004
Sendt: 10 August 2006 kl. 11:43 | IP-adresse registreret
Model 104/2
Model 104/2 is a classic high output, high sensitivity loudspeaker system with exceptional dynamic capability. Since its launch, this elegant Reference Series loudspeaker has won awards worldwide for technical innovation and acoustic performance - and no wonder. Model 104/2 incorporates KEF Reference Series dual coupled cavity bass loading, an innovative arrangement which improves low frequency performance and reduces distortion while delivering tremendous bass output. Twin chassis-less midrange units effectively eliminate chassis resonance. The very embodiment of all that makes Reference Series so special, Model 104/2 has a performance level way above its size.
Model 104/2 Specifications
Frequency Range 55Hz - 20kHz (+/- 2dB)
Drive Units HF: T33 25mm (1") Impregnated fabric dome
MF: 2 x B110 100mm (5") Doped Bextrene cone
LF: 2 x B200 200mm (8") Paper cone
Crossover Point 150Hz, 3kHz
Nominal Impedance 4 ohms
Characteristic
Sensitivity Level
92dB
Amplifier Requirements 25-200W into 4 ohms
Maximum Output 112dB
Internal Volumes LF 50 litres
MF 3 litres
Net Weight 32kg (70.5lbs)
Dimensions
(H x W x D)
900 x 280 x 415mm
35.5 x 11 x 16.4 ins
Mickey BG
Sendt: 10 August 2006 kl. 12:01 | IP-adresse registreret
= der er en 8" indbygget :o)
My Place - Sound of Life
finn52
Sendt: 10 August 2006 kl. 12:15 | IP-adresse registreret
Der er 2stk. 8" indbygget, hvilket fremgår af specifikationerne vist ovenfor.
piobyte
Sendt: 10 August 2006 kl. 12:25 | IP-adresse registreret
På forhånd tak.
Dejlig ht. havde den selv i mange år. Det jeg stadigvæk  er meget imponeret over er mellemtonen, en lilletromme med knald på har jeg sjældent hørt bedre end på 104/2.
Bassen går ikke forfærdenligt dybt og den prøver heller ikke på det som mange andre der booster den helt vildt,  Prøv at tjekke kantophængene på basserne , mine var med skumkanter men de er så vidt vides også lavet med gummi .
Jeg måtte på et tidspunkt skifte ophæng .
 De vil gerne have en stor forstærker med styr på tingene da de er ohmsk liniære ( 4 ohm)
 Tillykke med dem.
http://www.piobyte.dk/MSV2
Holmen
Sendt: 10 August 2006 kl. 13:00 | IP-adresse registreret
piobyte, det er ikke let at se ophængene, så skal jeg have et spejl ind og lyse med en lommelygte, men jeg er ikke i nærheden af dem nu, så jeg har ikke mulighed for det. Men ja, det er et dejligt sæt HT'ere, Mht. forstærker, så spiller jeg med en Electrocompaniet ec 1forforstærker og Electrocompaniet ampliwire 100 effektforstærker, som mig bekendt leverer 2 x 100 W i 8 ohm. Den  virker stærkere end andre 100 watts forstærkere jeg har prøvet.
finn52, hvor har du fundet de data henne?
Tak for hjælpen.
finn52
Sendt: 10 August 2006 kl. 15:37 | IP-adresse registreret
