Tilbage til HIFI4ALL.DK 24. juni 2026 | 19:55
Emne Emne: Dipole surround vrs. Normal Speakers (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
jemscool
Bruger siden: 14 September 2004
Sendt: 26 Februar 2005 kl. 15:30 | IP-adresse registreret
I'm looking for a good sound for a 35 quadrate meter room, also
need to find som good LCR's . If anyone can help me with choise of
speakers, please tell me what you think is a good speaker for
surround and music quality sound, was thinking about M&K's THX set
150 or .higher.
MVH
Cool
Til top Vis jemscool's Profil Søg efter andre indlæg skrevet af jemscool
Ronin
Lyd og Billed Vodskov
Sendt: 26 Februar 2005 kl. 17:45 | IP-adresse registreret
THX-speakers is not, by definition, as good in musical-performance as they are in surround-mode, and most speakers will do a sufficient job working as both surround- and music performers. I were you, I would go for normal speakers which, in most cases, will be adequate for both parts of the show.
The biggest question is almost the most obvious of them all - what budget are you operating in?
www.tapeconnection.dk can deliver a complete DLS-setup at reasonable prices. Other possibilities are Dali, System Audio and a whole bunch of others with great value for the money spent! Your needs and demands for looks and design are also important to know!
jemscool
Sendt: 26 Februar 2005 kl. 23:53 | IP-adresse registreret
Thanks for your help, the problem is just that : it's a jungle of
products out there, and if you buy the wrong speakers, you'll take a
loss, of about 50%. I would like to buy a suround set for upto
50,000DKR. But must be quality.
MVH
Cool
Ronin
Sendt: 27 Februar 2005 kl. 00:00 | IP-adresse registreret
Yeah, it´s one big and very confusing jungle, but luckily there´s this great forum to seek assistance in!
50.000 Dkr. is a lot of money and they will easily get you very far - look at the market for used products.
I know this is a bit more money, but it´s a great example of a very complete setup doing both musical and surroundperformance to the max.
http://www.hifi4all.dk/markedsplads/Annonce_S.asp?iType=2&am p;iAd=31497
jemscool
Sendt: 27 Februar 2005 kl. 19:15 | IP-adresse registreret
Ronin
Thanks for your help again, will check out these B&W's which I know
should be great, maybe a bit over my budget.
But I appreciate your help alot.
Thanks Jens
