Tilbage til HIFI4ALL.DK 15. juni 2026 | 04:22
DVD, HD-DVD, Blu-ray
Emne Emne: Momitsu Projektorvenlig DVD (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
dalle
Sendt: 15 Marts 2005 kl. 14:08 | IP-adresse registreret
http://www.momitsu.nl/v880n/default.html
Create a multimedia living cinema in your own house using the highly advanced video upscaling possibilities of the Momitsu V880N. Because of the integrated WIFI and LAN you can easily watch the entertainment located on your pc by sending it to your  (1080i) television or projector.
  • Wireless* and 10-100 ethernet connection
  • USB-connection
  • Supports 480P & 720P & 1080i  (HDTV)
* Wireless by optional PCMCIA card
Mediacenter til afspilning af film/musik på pc
Model Name
DVD-V880N
Support Media
Compatible with DVD, DVD-R, DVD+R, DVD-RW, DVD+RW, VCD, SVCD, CD-R, CD-RW, CD-DA, CDI-digital, MP3 ISO, MP4 ISO
Support Video Format
MPEG1, MPEG2, MPEG4 (AVI), JPEG (JPG)
Support Audio Format
MPEG 1, LAYER 1, LAYER 2, MPEG 3
TV System
NTSC/PAL
Audio System
2 Channels
5.1 Channels Dolby Digital AC-3 and DTS output
Audio DAC
96KHz/24-bit
Video D/A Converter
10 bit
Maximum DVI Resolutions
1920x1080
Video Output Terminals
NTSC/PAL 4:3, 16:9 Progressive Scan
1x Composite RCA output
1x S-Video
1x DVI-I supports 480p, 720p, 1080i output (also 50Hz)
1x Component (Y/Pb/Pr) , support 480p, 720p, 1080i output
1x SCART output
Video Input Terminals (Optional)
S-Video
Component (Y/Pb/Pr)
Audio Output Terminals
1x Built-in Headphone output with volume control
1x Coaxial output
1x Optical digital output
2x Stereo audio RCA output
Network Terminals
1x 100BASE-TX/10BASE-T (RJ-45)
1x
PCMCIA expansion slot
supports wireless 802.11b network (card not included)
Support Format via Ethernet
• Video-on-demand supporting
- MPEG 1 VCD format (1150Kbps CBR) (.mpg, .mpe, .mpeg, .dat, .m1v)
- MPEG 2 up to 9Mbps (.mpg, .mpe, .mpeg, .m2v, .vob, .vro)
- MPEG 4 (OpenDivX, XviD, RMP4) (.m4v, .avi, .divx, .xvid, .rmp4, .mov, .mp4)
- AVI audio codec: MP3, AC3, PCM, WMA, Ogg
- MOV : 3ivX + MP3, 3ivX + PCM, 3ivX + AAC (3ivX converted from supported MPEG 4 video codec using Dr. DivX II for MAC OS)
- MP4 : MP4V + MP4A (AAC) (only support non-hinted MP4)
• Audio-on-demand supporting
- MPEG I Layer 1 (MP1) (.mp1, .mpa)
- MPEG I Layer 2 (MP2) (.mp2)
- MPEG I Layer 3 (MP3) (.mp3)
- Ogg Vorbis (OGG) (.ogg)
- AC3 5.1 (AC3) (.ac3)
- Microsoft PCM Wave (WAV) (.wav)
- Advanced Audio Coding (AAC, ADIF, ADTS) (.aac)
- Apple MPEG4 AAC Audio (M4A) (.m4a)
- Microsoft Windows Media Audio version 1 and version 2 (WMA) (.wma)
• Photo Album (JPEG) with all the supported audio format as background music.
• Internet Radio supporting Shoutcast server MP3 Internet Radio stream.
• Picture-in-Picture (Video in window) feature supported.
• Playback controls: Play/Pause, Go to (seeking), Fast Forward/Rewind, Slow Motion (MPEG 1 and 2 only).
• Audio and Video Playlist supported.
Back panel
Remote
Full Remote Control function
Power Requirement
AC 100V-240V +- 10% , 50/60 Hz, 20W.
Size
430mm(W) x 300mm(D) x 68mm(H)
Weight
5 Kg
Included Accessories
Remote Controller, RCA-RCA Cable, Power Cord, Instruction Manual
Operating Temperature
5 40 degrees C
Operating Humidity
5 85%
Prisen er 365Euro leveret til døren inkl alt.
Vil dette være et godt bud på en god og billig DVD/Htpc?
Hvis jeg har en masse film liggende på pc'en, vil denne så kunne levere et bedre signal ifht Mediacenteren på Xbox?
Hvordan er specs ifht de populære afspillere fra Denon og Pioneer?
Vil den også kunne bruge opscaleren til at forbedre et TV signal?
Fedt at den er foreberedt på Video on demand. Den lader til at slå Kiss på specs ifht prisen.
Til top Vis dalle's Profil Søg efter andre indlæg skrevet af dalle
kyhn
Bruger siden: 05 Februar 2004
Sendt: 15 Marts 2005 kl. 14:29 | IP-adresse registreret
http://www.hifi4all.dk/forum/forum_posts.asp?TID=19211&K W=momitsu
der var en bruger herinde der havde fået en, kan bare ikke lige huske hvem!
dalle
Sendt: 15 Marts 2005 kl. 17:45 | IP-adresse registreret
Okay, den ser da spændende ud. Tror de snakker om versionen uden netværk og media center i linket ovenfor. Kunne være rart med nogle kommentarer på scaleren ifht projektor.
dalle
Sendt: 18 Marts 2005 kl. 09:02 | IP-adresse registreret
ingen kommentarer. Den virker da ellers som en interessant afspiller.
RogueAgent
Bruger siden: 09 Januar 2004
Sendt: 18 Marts 2005 kl. 10:00 | IP-adresse registreret
Momitsu´en uden net/mediacenter er såvidt jeg ved identisk med Yamakawa 365/375.
Den indbyggede scaler er ganske god, synes jeg - jeg har Yamakawa 365 koblet til Panny AE500 med DVI, og foretrækker at lade afspilleren stå for skaleringen til 720p.
Jeg har set andre herinde som foretrækker at lade projektoren gøre det, så det må under alle omstændigheder komme an på personlig smag og behag.
