Tilbage til HIFI4ALL.DK 18. juni 2026 | 16:49
Head-fi
 HIFI4ALL Forum : Head-fi
Emne Emne: WooAudio 22 og "pop" i lyden (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
rasmusvn
Bruger siden: 05 Februar 2006
Sendt: 02 Juni 2010 kl. 16:35 | IP-adresse registreret
Jeg oplever nogle småproblemer med min WA22. Da mailen også er sendt til Woo, får I her den engelske udgave, da jeg er lidt doven :)
Input til hvad problemet kunne være er velkomne, det er ikke muligt at flytte forstærkeren grundet begrænset plads.
Hey
I own the WA22 and I'm expreriencing a problem with a noise (small pops) and not a light hum or anything like that.
These "pops" only occure rarely but they do occure. They are not loud but they are noticable.
The problem only manifested itself after I recently moved to a new apartment.
As far as I can tell the source of the problem could be the power source.
The reason for this belief is that all the powerplugs in the end connect to the same fuse (there's only one "group" in the fuse-cabinet).
When turning on a fluorescent lamp the same noise occurs (only more rapidly) as it is turned on; is this an indication of anything?
Would the solution be to try a power-filter like this one: http://www.xindak.com/english/products/showditail.asp?id=308  ?
As far as I can tell nothing is wrong with the tubes as I've tested useing the standard tubes versus the "upgraded package" of tubes. The only odd thing I noticed is that one of the Shuguang Treasure CV181-Z tubes flashes when turned on.
So does the princess tube but this flash just seems different from how the other Shuguang Treasure CV181-Z behaves. I've tried swapping the two driver tubes but the noise doesn't seem to manifest itself to only one channel.
Currently the WA22, the DAC and the Sonos is spaced together with a wireless router and other equipment in a very tight space but this didn't seem to be a problem before I moved.
There are alse plenty more wireless networks in this area.
As a result of this i think the main culprit is the power source. Notice that when the amp, source and DAC is on but no music is playing the pops don't occure.
Til top Vis rasmusvn's Profil Søg efter andre indlæg skrevet af rasmusvn
rasmusvn
Sendt: 05 Juni 2010 kl. 23:33 | IP-adresse registreret
Så ser det ud til, at jeg fil løst problemet, hvis man ellers kan sige det sådan.
Udstyret blev afprøvet andetsteds, altså var strømkilden også en anden.
Resultatet: at de irriterende "puf" forsvandt.
Henrik_sdk
Bruger siden: 03 Oktober 2008
Sendt: 06 Juni 2010 kl. 08:22 | IP-adresse registreret
Jeg ville også have skrevet du skulle flytte til sjælland, men det var godt du fandt fejlen
Til top Vis Henrik_sdk's Profil Søg efter andre indlæg skrevet af Henrik_sdk
rasmusvn
Sendt: 11 Juni 2010 kl. 23:30 | IP-adresse registreret
Lige en lille opdatering.
Jeg har nu testet med en strømskinne fra PS Audio (med filter) samt en passiv MIT strømrenser, begge venligst udlånt af Vassago.
Konstatering: De har ingen effekt.
Jeg har ligeledes haft lånt en Purepower enhed, den har heller ikke nogen effekt.
Jeg har dog haft testet setupet et andet sted, og her er der ingen problemer.
Da det negative som oftest viser sig langt mere end det positve, skifter jeg derfor min WooAudio 22 ud med en Red Wine Audio Isabellina HPA, så burde strømmen ikke længere spille en rolle :).
Så hvis nogen skulle have lyst til at gøre et røverkøb på en WA22, kan de kigge i KSB, ellers bliver den brugt ifb. med en byttehandel til en Isabellina HPA.
techtrino
Bruger siden: 19 Juni 2006
Sendt: 11 Juni 2010 kl. 23:33 | IP-adresse registreret
Er selv glad for min RWA, men du kan løse problemmet. Du skal have en skilletrafo, det er det eneste der duer, en 400-500VA skulle sagtens kunne klare det og en brugt koster en 2-500kr
Så har du helt rent strøm og er skilt fra nettet
rasmusvn
Sendt: 12 Juni 2010 kl. 00:55 | IP-adresse registreret
Så vidt jeg kan se, burde en Purepower have nogenlunde samme effekt.
Jeg blev dog træt af "problemet" og tog derfor den "lette" udvej.
techtrino
Sendt: 12 Juni 2010 kl. 12:38 | IP-adresse registreret
Kender ikke purepower, men kun hvis den vejer over 5-10kg så har den en effect, alle de der "conditionere" har minimal effekt
AffeX
Bruger siden: 09 Juni 2009
Sendt: 15 Juni 2010 kl. 22:56 | IP-adresse registreret
Rasmus problem med 'pop' i hans WA22 synes løst. Han har nemlig solgt den til mig.
Nu er der ingen 'pop' - kun blød cremet jazz
Det ser ud til, at det var et problem med strømmen der hvor han bor (hvilket han også selv har anført), for jeg har ikke registreret noget her.
WA22 er nu en dejlig forstærker, som driver mine HD800 balanceret gennem et medfølgende Moon Audio, Blue Dragon kabel.
Tak til 'rasmusvn' som lod sin forstærker få et nyt godt hjem her hos mig.
Til top Vis AffeX's Profil Søg efter andre indlæg skrevet af AffeX
burning777
Konsulent ved B&O
Bruger siden: 28 Maj 2007
Sendt: 18 Juni 2010 kl. 23:47 | IP-adresse registreret
Tillykke med den!!! Så har du i det mindste noget at hygge dig med indtil dit byggeprojekt er færdigt
Til top Vis burning777's Profil Søg efter andre indlæg skrevet af burning777
rasmusvn
Sendt: 29 Juni 2010 kl. 12:37 | IP-adresse registreret
Så kom der rødvin for 21k ind ad døren personligt leveret af Carsten fra Schmidt Audio.
Problem løst :D.
Brian7500
Bruger siden: 12 April 2005
Sendt: 29 Juni 2010 kl. 12:41 | IP-adresse registreret
Problem løst :D.
Skål
Med venlig hilsen,
Brian7500
AffeX
Sendt: 29 Juni 2010 kl. 13:16 | IP-adresse registreret
Tillykke med din Issabellina. Den lyder altså også virkelig godt.
Jeg nyder nu glæde af din WA22 og jeg har ikke oplevet problemer her.
